It is currently Sat Jul 05, 2025 7:53 pm
 Post subject: Case splitter
PostPosted: Fri Jul 14, 2006 8:45 pm
What is a good ( easy to use ) case splitter ?? How about the Motion Pro one ?? I'll be using it on a 73 and 78 250.
thanks
PostPosted: Mon Jul 17, 2006 6:12 am
Haven't seen the motion pro one, but mine is just an automotive timing gear puller I bought at wholesale tool place for $7.95. Simply a straight bar with puller screw in the middle with two long slots. Had to buy two very long 8mm bolts at local fastener supply company (Rule Co.) to replace the 5/16 bolts it came with. Can't see how anything could be any easier. If the motion pro works the same way, piece of cake.
OK, I looked up a motion pro case splitter. If it is the adjustable three-way splitter, it should work fine on a CR case too, just need two of the arms. Kind of pricey.
PostPosted: Mon Jul 17, 2006 11:45 am
Funny, I just saw one of those in an auto parts store and wondered if it would work.. thanks
