It is currently Sun Jul 06, 2025 2:50 am
 Post subject: CR125M rear shocks
PostPosted: Sat Jul 08, 2006 11:04 am
Anyone give me any help with rear shock set up?
I have the standard 1976 125CR shocks with the airvalves so I can adjust the preload.
I am a rather heavy guy..possibly too heavy for my poor little bike...95 kg.
What sort of air pressure should I be putting into the shocks?
Can I buy heavier rated springs for these shocks?
thank you.
 Post subject: Shocks, 76 Elsinore
PostPosted: Sun Aug 06, 2006 10:28 pm
The stock shocks on the 76 CR-125 are 14.5" eye to eye. You may be able to locate stiffer springs from Works Performance which will fit; I have two pairs of Works shocks in those lengths. A new pair of Works shocks would probably work well, as they will make a custom pair of shocks for you based on your weight and ability level. They are about $300 a pair.
Users browsing this forum: Google [Bot] and 44 guests
