It is currently Sat Jul 05, 2025 8:30 pm
PostPosted: Thu Sep 07, 2006 6:00 pm
Can someone please give me the info I need to buy the correct flywheel puller for a CR 250M... I have bought two that were labeled as the right one but they would not work!
thanks
PostPosted: Sat Sep 16, 2006 12:09 pm
I had the same issue with mine, (75 elsi 250).. I've bought two pullers and they both don't work. The issue with mine is that the crankshaft end sticks out past the rotor. Called AMS and was told they don't make a puller for my bike, so the first time I used a "3 finger" puller.. Put pressure on it, heated up the rotar and it poped. .
Now I have made a puller.. I took a bolt (size that screws into the rotor, drilled a hole through it, tapped for a bolt (8mm I think), then countersunk the other end so it would screw into the rotor and go over the crank.
Back the 8mm bolt off, screw the big bolt into the rotor, then tighten the smaller bolt (pushes on the crank end), and it will pop off..
Frankie
75 Honda 250 Elsinore
Findlay, Ohio
