It is currently Mon Jul 07, 2025 1:44 am
 Post subject: '73 CR250 engine paint?
PostPosted: Sat Oct 21, 2006 11:26 pm
I'm wanting to repaint my '73 CR250 engine cases along with the top end and was wondering if anyone has suggestions on the paint. I've seen paint offered from PJ1 and other makers and wondering if this would work to match the original style.
PostPosted: Sun Oct 22, 2006 8:40 pm
I have used PJ1 Satin Black engine & case paint. Very happy with the results but I have not run my MR that hard to see how it holds up. It's a very thin paint, easy to run tho-
PostPosted: Mon Oct 23, 2006 6:17 am
VHT make a satin black barrel paint which is chemical, chip and heat resistant which is pretty good gear!
cheers
Rossco
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
PostPosted: Sat Oct 28, 2006 10:57 pm
What primer do you recommend for the vht paint?
Al Carr
73-74 CR250M Elsinore
78 CR250 Elsinore
2003 CR250R
PostPosted: Wed Nov 01, 2006 5:15 am
I think VHT make an etch primer as well - if not correct then just a standard etch primer - the temperature isn't too high to worry the paint I have found?
1974 Yamaha YZ360B
1977 Suzuki RM370B
1980 Honda CR250RA
