CR 480 carb doesn't fit!!!!
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1186
Author:  510rider [ Mon Sep 18, 2006 10:09 am ]
Post subject:  CR 480 carb doesn't fit!!!!
I have a 1983 CR480 that I got with a mikuni on it. Problem is I couldn't keep the airboot from the box to stay on. I thought maybe the Mik was a "shorter" card. I put a Kehin on it off another 83 and it is shorter!!! I can't even get the clamp to stay on. So, could it have the wrong intake side ftiing? ( the one in front of the reeds). Can I get a Rad valve off of something that might work??? Any help would be great.
510 rider
Author:  expat [ Mon Sep 18, 2006 2:35 pm ]
May be good idea to put a photo on here so the lads can see.
One suggestion is your rubber boots may be shrunk from age and sun exposure..
Author:  sgt.bigjim [ Mon Sep 18, 2006 8:14 pm ]
i have a stock carb on my 480. it is also a tight fit. like previously mention, i think the rubber may have shrunk.
jim
Author:  redrocket190 [ Mon Sep 18, 2006 8:15 pm ]
The Moto Tassarini V-Force II reed valve from a 1987 Honda CR250R drops right in...
Author:  expat [ Tue Sep 19, 2006 12:51 pm ]
Google "Mossberger" ....they sell a 10mm "Torq spacer" that fits between cylinder and reed block.
The idea of spacer is to create more bottom end power, but , in your application, the spacer could well regain the lost airboot length. :)
Author:  510rider [ Tue Sep 19, 2006 6:22 pm ]
Looks like a spacer is my only option as both the intake boot and the airbox boot are not available. Thanks for the tip. I'll start on one tommorrow!!!!!!
510 rider
Author:  redrocket190 [ Thu Sep 21, 2006 1:06 am ]
I have a surplus, un-used 6 petal Mossbarger reed valve complete with torque spacer. Send me a message if you are interested.
Author:  510rider [ Tue Sep 26, 2006 6:24 pm ]
Redrocket190 please contact me about the reed block. I have e-mailed you through this site, but it might not be working correctly.
510 rider
Mark T
