HELP!! Need Oversize Piston for MR175
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1234
Page 1 of 2
Author:  Atkm [ Thu Nov 02, 2006 6:18 pm ]
Post subject:  HELP!! Need Oversize Piston for MR175
I'm restoring my 1977 MR175 that I owned since new.
I'm desperate for an oversize piston. I have exhausted all resources that I can think of. Wiseco, Honda etc is a no.
Can any of you gents point me in the right direction?
Thanks,
Mike
Author:  mdlafferty [ Sun Nov 05, 2006 8:12 pm ]
I can sympathize with you. I've been looking too. Wiseco used to make them because there was one on ebay last week that went for over $100. They no longer make them though.
Good luck.
Author:  Atkm [ Mon Nov 06, 2006 12:39 am ]
Thanks for sympathizing.
I have even phoned several dealers that appear to have the piston according to their online micro-fiche, part number 13102-373-000.
Once they do a physical stock check, it is not available.
In the automotive business, many dealers can do a "dealer-search" and find a NOS part elsewhere.....but it appears that the MC dealers I tried do not do this.
Mike
Author:  Gary Starr [ Mon Nov 06, 2006 8:19 pm ]
Here you go save your money I think it is in Euro's. Easy company to deal with they were the only ones who had the parts I needed for my MR 250
http://www.cmsnl.com/searchparts.php?s_ ... esults=100
Author:  VintageRacer [ Fri Nov 10, 2006 10:27 am ]
I have a US source that currently has these in stock but apparently their not the size you need. "quantity - description - price "
4 13011-373-015 RING SET STD 22.00
4 13013-373-015 RING PISTON 0.50 22.00
1 13100-373-000 PISTON (STD) 117.00
My other US source has these but again no oversize piston, only rings
13011-373-013 RING SET (STD) 6 $32.95
13012-373-003 RING SET (OS 0.25) 1 $32.98
13012-373-013 RING SET (OS 0.25) 7 $32.98
13013-373-003 RING SET (OS 0.50) 1 $32.95
13013-373-013 RING SET (OS 0.50) 5 $32.95
13013-373-015 RING SET (OS 0.50) 1 $24.98
13014-373-003 RING SET (0.75) 7 $32.98
13014-373-015 RING SET (0K75) 2 $39.95
13015-373-015 RING SET (1.00) 1 $26.95
13100-373-000 PISTON (STD) 2 $113.95
Vin
Author:  VintageRacer [ Fri Nov 10, 2006 10:36 am ]
UPDATE: I just found these pistons for code model 395 which is also a MR175 and maybe these will work.
1 13101-395-000 PISTON (STD) $92.95
3 13102-395-000 PISTON (OS 0.25) $92.95
1 13103-395-000 PISTON (OS 0.50) $88.99
Author:  Atkm [ Fri Nov 10, 2006 6:44 pm ]
Thanks Gary,
I tried emailing them, but no response yet.
They are in Holland, I believe?
Mike
Author:  Atkm [ Fri Nov 10, 2006 6:47 pm ]
Thanks for your reply, Vintage racer.
I think that Model Code 395 is for a MR250.
Even though the bore could be the same, the 250 has a longer stroke, so I don't think the pin-height on the piston would be the same, but I don't know.
Mike
Author:  Atkm [ Sat Nov 11, 2006 10:44 am ]
The older MR250's stock cylinder bore was 70 mm. The MR175 was 66 mm.
So..the MR250 (model code 395) piston will NOT fit a MR175.
I did receive an email from someone that has a Wiseco old stock oversize piston kit. I have emailed Wiseco to see if they can confirm that the partnumber is correct.
I'll keep you posted.
Mike
Author:  VintageRacer [ Sat Nov 11, 2006 1:24 pm ]
Sorry about that, I used a Model Code Website for that info and I guess their wrong. They actually have the MR175 and MR250 listed as the same code now that I checked again. Heres the link---
http://www.vjmc.org/techtips/honda_code.htm
Author:  Gary Starr [ Sat Nov 11, 2006 8:05 pm ]
Hi Mike- They are in The Netherlands, Holland is more like one of our states I guess. I just ordered what I needed, they emailed me in return.Did you email them with this address- mailto:info@cmsnl.com ? I was happy with them,they had parts I have been looking for a long time for my MR and fast shipping also.
Author:  Gary Starr [ Sat Nov 11, 2006 8:11 pm ]
The MR 175 product code is 373
Author:  Atkm [ Sun Nov 12, 2006 1:10 pm ]
Thanks Gary,
No, I didn't try them. I tried other Honda dealers that had the MR-series listed on their online microfiche.
I looked around on CMSNL's website and I will certainly give them a try .
Thanks for the info,
Mike
UPDATE:
Doing a parts-search by part-number, CMSNL had NO piston parts for the MR175, NO airfilter and NO clutch-cable. This seems to be the same among all the part-suppliers for this model.
I seem to be *&^% out of luck....but I'll still email them and see if they can get a piston.
Mike
Author:  Gary Starr [ Sun Nov 12, 2006 5:19 pm ]
Mike - when I gave you the link they were on there and now they are not. They still list a cable tho. Go to search by part number and in center 3 digit field type in product code 373, that will give you all the parts they have. Check out denniskirk.com,they used to list clutch cables by motion pro.
Author:  Atkm [ Tue Nov 14, 2006 11:30 pm ]
I did a parts search on CMSNL. Thanks Gary Starr, for the tip.
There is a way to check parts "backwards" there as well. I found that many parts for the MR175 do not necessarily have the -373- number.
I found out that the clutch cable number has changed up and is now interchangeble with other model codes such as for the CR125 and MT 125.
So, Gary you are right, Cmsnl DO list many parts for the MR175.....
....except ANY pistons :cry:
Mike
