It is currently Mon Jul 07, 2025 4:33 am
PostPosted: Sun Dec 03, 2006 3:23 am
Guys
I run a stock standard 76 cr125m and I want to buy a new carb.
What make and model should I go for...keihin or mikuni?
many thanks
Ruairi
 Post subject: Carb for 1976 CR125M
PostPosted: Tue Dec 12, 2006 11:32 pm
I have a 76 CR125M with the stock carb and it runs really well with the right jetting. If I had to replace it, my experience with the 1974 CR 125M is a Mikuni 32 or 34 mm diameter carb is the way to go. In vintage racing, it seems the majority of people are using Mikuni's on the 74 CR125 and CR250. I see a lot of stock Keihins on the 76 CR125's that are still being raced, so I'm not sure how much you will gain in performance with a Mikuni. Keihin or Mikuni, jet it as good as you can get it and you should be OK.
PostPosted: Wed Dec 13, 2006 2:42 am
Many thanks for your advice Carl.
You have confirmed what I have been advised by others.
I have decided to go for the VM32 Mikuni.
My bikes are stock standard and I will only be using standard jetting to start off. The "performance" I am after is just better starting and running. The Keihins I have are pretty scored out on the throttle slide and worn around the throttle screw stop and this all makes a difference.
Thanks very much to everyone who has given me sound mechanical advice on this board over 2006.
Heres to a more peaceful 2007.
