It is currently Sun Jul 06, 2025 5:08 am
PostPosted: Mon Dec 11, 2006 9:09 am
I saw a old cylinder and head Bead Blasted. I never had anything bead blasted and wanted to know is this a good way to clean up a old cylinder or a head. Is bead blasting only good for outside of a motor part. Does bead blasting hurt the inside of the cylinder or inside of the head. The photo is a cylinder and head that was bead blasted.
AHRMA #13k
SEVMX #13k
1982 Honda CR480
1983 Honda CR480
1978 Suzuki RM50
2006 Honda CR250R
1973 Yamaha MX250
PostPosted: Mon Dec 11, 2006 7:47 pm
There are many types of media that can be used to clean parts...Depends on what you expect the final finish to look like.If your doing a nut and bolt museum resto and you dont want to alter the metal in any way, try using walnut shells,plastic media,soda or a chemical stripper. This usually uses less psi which will cause less damage or texture changes to the metal.Make sure you cover any machined,metal to metal gasketed surfaces with a heavy tape or gasket(so you maintain a good sealing surface) and I would mask exposed studs or threaded holes as well.Also clean and re-clean all the parts that come back from the stripper as to not contaminate your engine or parts during re-assembly. eL
1974 Honda CR250M
1979 Honda CBX SS
