74 mt250 electrical parts?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=127
Author:  Guest [ Wed Feb 11, 2004 9:51 pm ]
Post subject:  74 mt250 electrical parts?
Does anyone know of a source for new stator silicon rectifier ect.
The stator seemes ok except one of the brass pins is missing on the w/b wire
the rectifier has a tab broken that was attempted to be soldered on
I've checked Red Racer, Vintage Iron(dont want to spend 450 on electronic upgrade yet), and anything else that showed up no one semes to have these pieces
Author:  Kickitagain [ Sat Feb 28, 2004 3:21 pm ]
Post subject:  silicon rectifier
I've been using the radioshack diode method for the past year and half on my 74 MT250. My old rectifier was leaking voltage due to a bad diode. You'll never find a cheeper fix. Works better than the original. Just solder the old wires to the 4 lugs. Check it out. http://204.29.80.50/restore/diode/diode.html
