CR Motor with MT barrel and head https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1313 |
Author: | jacer [ Fri Jan 26, 2007 4:58 am ] |
Post subject: | CR Motor with MT barrel and head |
I bought an MT125 that has a CR motor, although with an MT head (has two plug holes). My questions are: 1. How do I tell if it has a MT barrel or a CR barrel (it has rubber 'plugs' between the fins so I suspect MT. Is this the way to tell? 2. Assuming it is a MT barrel and head - are there significant differences to the CR? Would performance be much different? Thanks in advance for any response! |
Author: | mdlafferty [ Tue Jan 30, 2007 10:46 am ] |
Post subject: | |
If the cylinder has the rubber plugs it is likely an MT. An MT also has the threaded hole at the intake where the oil injection connects. CR doesn't have this hole. An MT cylinder performs pretty well if you use the CR carb and CR pipe. It doesn't quite have the peak top end power of the CR but it has way more bottom end torque. Much nicer for trail riding. I had my 11 year old son learn to ride on that setup. ![]() |
Author: | jacer [ Wed Jan 31, 2007 4:41 am ] |
Post subject: | |
Thanks for your response! |
