Part ID for Rebuild
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=13202
Author:  Patriot93 [ Sat May 18, 2019 8:47 pm ]
Post subject:  Part ID for Rebuild
Hello. I have an 74 CR250 Crankcase that I am rebuilding. However, I have a part that I have no idea what it goes to. Any help would be appreciated! The closest thing I see to it in my parts manual is in the gear shift drum, with it being 4 small cylinders. But I never had that pulled apart.
https://share.icloud.com/photos/0KhlPgx ... Q#Galt,_CA
Author:  m@tt [ Sun May 19, 2019 12:14 pm ]
Post subject:  Re: Part ID for Rebuild
They look like locating dowels
Author:  Patriot93 [ Sun May 19, 2019 12:45 pm ]
M@tt,
Do you know what they would have came out of? Everything was blown apart in a box. I’m looking along the edge of the case, but not seeing small enough holes for them to insert. Thanks!
Author:  m@tt [ Sun May 19, 2019 4:02 pm ]
They should be visible on 2 of the screw holes that join the 2 crank cases together - you can try them in the gasket holes either end of the engine
Part# 26 on CMSNL here
https://www.cmsnl.com/honda-cr250m-elsi ... OGj_4rTWhB
Author:  Patriot93 [ Sun May 19, 2019 5:43 pm ]
Unfortunately that’s not it. I have all those. This is much smaller and not hollow.
Author:  m@tt [ Mon May 20, 2019 9:11 am ]
Apologies now I see them in your hand they’re clearly not the dowels I was thinking of
I think you’re right with your initial assessment and they’re 2 of 4 rollers in the shift drum if they measure 10x4 mm according to item 23
https://www.cmsnl.com/honda-cr250m-elsi ... OLCdYrTWhA
