It is currently Mon Jul 28, 2025 6:51 pm
PostPosted: Sun Jul 14, 2019 2:34 pm
Question for someone having the OEM upper muffler mount special bolt (8x17) 90138-357-010 labeled #24 on parts diagram installed on a 74 Cr125m. The parts diagram shows a 8mm flat washer 94101-08000 (#25 on diagram) to be used with this as well as the rubber cushion. The bolt is "shoulder type" which would not allow fitment of the washer. Is this a diagram error?? I'm wanting my restoration to be as correct as possible. Thanks all.
Roy
