It is currently Tue Jun 17, 2025 1:57 pm
PostPosted: Tue Mar 02, 2021 12:40 pm
I bought a set of Allen screws for the racer I’m building. There is one case bolt that is 70mm long that won’t work anywhere. The stock screw is 70mm but is threaded for most of the screw. Which hole does it go in? The manual doesn’t say and when you drop them in the case they are sticking up the same amount. It looks like one hole goes through to the clutch side and looks right but not 100% sure. 1974 CR250M.
PostPosted: Tue Mar 02, 2021 4:30 pm
From memory the only 70mm screw connects the two crank halves . Probably the lower hole on the LH case (not behind the stator)
