Bonjour Mark! Hello Sam !
(Mark, parles tu français ?
Thank you very much for your reply . I was about to cry.... I am glad to see I am not alone to think about GEM reed cage...
I will email privately to the dear Sam . I am very interesting to see instruction sheet !
Mark, my first idea is the same like yours. The piston should be cut a little bit in order to let the intake port do a longer job
I am also wondering how we arrange the situation concering the air boot .... if the original is kept, it means it should be tighted a lot at the back side .Mark how do you think ? do you have a special air boot or not ?
Sam is perfectly right concerning the cylinder "ruinning". Actually the reed valve need some clearance at the entrance of the cylinder. So a milling job must be done ...
Sam, when you say "hurt a little the top end"....do you mean it decrease the top end power ??? Is it really noticeable or is it just a small feeling ?
In others words, dear Sam, if you were in my position, would you install or not the gem reed cage ?
Thanks in advance
Thierry
