Removing tree stem https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1348 |
Author: | Go4Ducks2 [ Sun Feb 18, 2007 8:03 pm ] |
Post subject: | Removing tree stem |
Getting ready to take the stem out of the lower tree on an 81 cr250. Question is: Looks like I will have to press it out, my concern is how frozen the stem(steel) is to the lower tree(aluminum) and fear of cracking the lower tree. Am I forgetting something before I do this? Everythings off(lower bolt is out) except the lower bearing, stem and tree, soaked it in penetrating oil and getting ready to do it Tuesday. It should press out, correct and the lower bearing should also come off at the same time? |
Author: | JBACE [ Sun Feb 18, 2007 8:33 pm ] |
Post subject: | |
I had mine pressed out last week ('81 CR 450). My machinist had the same concerns about the aluminum. Instead, it practically fell out. Proceed with caution, but yours shouldn't be difficult either. |
Author: | redrocket190 [ Mon Feb 19, 2007 11:39 am ] |
Post subject: | |
I had my 1979 steel steerer transferred to a set of 1982 43mm aluminum triple clamps. A motorcycle shop with a hydraulic press did it in minutes for a 10 bucks... |
Author: | Go4Ducks2 [ Tue Feb 20, 2007 4:42 pm ] |
Post subject: | |
Came right out just like you guys said.....had a buddy of mine do it at his shop and he cleaned the trees up for me while I was there, think I'm gonna go all natural aluminum look top and bottom. What do you guys use to seal...I was thinking clear acrylic??? got the lower fork tubes nice and clean and polished, so I'll spray it all at the same time. |
Author: | redrocket190 [ Tue Feb 20, 2007 6:43 pm ] |
Post subject: | |
I had the 43mm triple clamps powder-coated black when I put them on the '79 CR250R to match the original ones. The silver ones on the other bikes are original... |
