tank rust
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=136
Author:  bobo [ Fri Feb 20, 2004 8:43 pm ]
Post subject:  tank rust
What's the best way to remove rust from gas tank?
Also what's the proper sixe carb for a 74 mt250?
Author:  Rick [ Fri Feb 20, 2004 10:04 pm ]
I always used course gravel. Remove all gas, rinse it with water and put a quart or two of gravel in it. Shake it as hard as you can for maybe 1/2 hour. Empty it out, rinse it for several minutes, air dry it and put gas in the same day.
Be forwarned: Your tank may begin to leak now. This is due to the rust eating almost all the way through already.
Author:  Guest [ Sat Feb 21, 2004 12:30 pm ]
thanks. rust isnt too bad allready took outside to metal no cancer eating through the outside
Author:  elgueche [ Sun Feb 22, 2004 1:01 pm ]
1 part molasses 5 parts water - mix it - fill tank and let sit for 2 weeks - clean up - i then use qwik poly that i got from the xs650 society - works a treat and you can save and reuse you mixture for latter - this is also listed on thevincent.com site - just finished same on a cl350 tank - oh and you can lick you fingers during the mixing if you want - sweet
