CR 125 Year Model?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=138
Author:  Mike$ [ Sat Feb 21, 2004 8:00 pm ]
Post subject:  CR 125 Year Model?
I have an engine case that is marked JE01E no numbers below it. I think that means it is 125cc. The clutch arm is on the right side and comes out of the BOTTOM of the engine. I have never seen a clutch set up this way. Can anyone tell me what year this engine might be? Thanks.
Author:  Guest [ Sun Feb 22, 2004 11:05 am ]
Post subject:  CR125R case numbers
All the '79 to '82 CR125R's have the JE01E markings, the way to ID what year of bikes it's for is by the SN#; 20XXXXX -'79, 21XXXXX -'80, 22XXXXX -'81.
Author:  Mike$ [ Sun Feb 22, 2004 11:18 am ]
Thanks! That points me in the right direction. I've posted pictures of the engine case at:
http://f2.pg.photos.yahoo.com/ph/muchocerveza@sbcglobal.net/album?.dir=/2758&.src=ph&store=&prodid=&.done=http%3a//f2.pg.photos.yahoo.com/ph/muchocerveza@sbcglobal.net/my_photos
I think this was a replacement case from a Honda dealer. It has NEVER been assembled.
My only other question is, will it will work for all CR125s 79-82? Or were there differences?
Author:  Nathan [ Tue Feb 24, 2004 8:26 am ]
Mike,
Starting in '81 the CR went to water cooling so that will probably rule out the use of these cases on those model years.
Nathan
