Finally giving up and admitting I didn't get my clutch-side main seal seated correctly last winter. No matter how I jet, still wayy too much smoke, poor idling and foul plug about every 5 miles on a trail. So I got a new seal.
My Shop Manual, of course, tells me nothing about replacing this. I think I just guessed which direction to turn it last time. This is the big seal that is smooth on one side and has several raised spots, about 3/8" long on the opposite side. Which direction is it supposed to be installed???
I remember the crank has a step down between the seal and the bearing and I was just hoping I got the seal to go over the right part of the crank when I assembled the crankcase.
Last time, I put the seals and bearings in the crankcase halfs, placed the crankshaft and gears in the right side case, stuck the other case on and tightened bolts until cases were tight.
I'm thinking this time about not putting the right side bearing in until the cases are together and I can stick my finger in around the edge of the seal to see whatever. Need any advise I can get because I really hate splitting the cases more than I have to. Thanks.
