CR250 Elsinore
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=147
Author:  Chuck Reuben [ Wed Feb 25, 2004 12:24 pm ]
Post subject:  CR250 Elsinore
How similar is the 73 and 74 CR 250's. Are all parts and specs similar.
Author:  FirePig [ Wed Feb 25, 2004 8:28 pm ]
The first boatload had some tranny problems and cracking in the frame where the swingarm bolts in. They also had a billet crank so had more lower end compression and moved the charge into the cylinder faster. Not to many of these were produced. Couple hundred I think and only a rare few left.
The next shipment had a bit of reinforcement on the frame around the hole where the swingarm pivot bolt goes through. I think they changed the tempering of some of the gears also. (Someone correct me if I'm wrong here.)
The parts seem to be all interchangeable.
Loren
