It is currently Mon Jul 07, 2025 8:49 am
 Post subject: 76 cr fuel tank?
PostPosted: Fri Jun 15, 2007 8:29 am
Is there a difference between the 76 cr125 and 250 fuel tanks? I need a tank for my 250 and want to know if a 125 will work. thanks
 Post subject: Re: 76 cr fuel tank?
PostPosted: Fri Jun 15, 2007 11:26 am
Site Admin
The CR125 tanks are a different shape and hold less and are made of steel, not aluminum like the CR250 tanks. As for the hole alignment in mounting the 125 on the 250 I couldn't say, but I'm sure someone else on the forums has tried it and will post an answer.
PostPosted: Sun Jun 17, 2007 1:21 pm
You can use the clarke RC plastic tank for both the 125 and the 250.
I bought 3 new tanks from clarke and have them on both my 76 & 77 125's and on my 75 250 which is the same as the 76 250. they do not use the rear bolt mount. The seat and a few plastic zip ties works. Make sure you get the fuel valve they have those available also.
Kevin
Kevin Politte
PostPosted: Mon Jun 18, 2007 7:03 am
Any chance you could post a pic of the RC tank on the 250???
PostPosted: Mon Jun 18, 2007 8:02 am
I was not able to add images. Not sure how to. My lack of knowledge. If you send e-mail to mailto:flashptA10@AOL.co I will e-mail pics. Then maybe you can post for me.
Kevin
Kevin Politte
PostPosted: Fri Jun 29, 2007 1:17 pm
Mitchie, I'll try to post: I had the clark RC tank on my MR for a while. In the picture, i'm usin g a CR seat, it fit the back of the tank better.
To Mount: I used 2 big rubber corks that fit the round hole in the fron gussets, drilled a hole to fit a long mounting bolt that went thru the tank, cork, frame, ect. The tank mounting holes are a few inches short of the stock threaded bosses.
Switched tanks after I ran out of gas on the trails. RC tanks looked cool, but not big enough for trail riding!
PostPosted: Fri Jun 29, 2007 1:18 pm
PostPosted: Fri Jun 29, 2007 1:22 pm
Well, I'm not having any luck posting either. Mitchie, PM me with your email address, I'll send photos directly to you.
