It is currently Sun Aug 17, 2025 12:09 pm
 Post subject: CR250 Elsinore
PostPosted: Wed Feb 25, 2004 12:24 pm
How similar is the 73 and 74 CR 250's. Are all parts and specs similar.
PostPosted: Wed Feb 25, 2004 8:28 pm
The first boatload had some tranny problems and cracking in the frame where the swingarm bolts in. They also had a billet crank so had more lower end compression and moved the charge into the cylinder faster. Not to many of these were produced. Couple hundred I think and only a rare few left.
The next shipment had a bit of reinforcement on the frame around the hole where the swingarm pivot bolt goes through. I think they changed the tempering of some of the gears also. (Someone correct me if I'm wrong here.)
The parts seem to be all interchangeable.
Loren
