cr250m 1973 will 1976 motor parts fit
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1529
Author:  jimg1au [ Mon Aug 06, 2007 8:12 am ]
Post subject:  cr250m 1973 will 1976 motor parts fit
hi
i have read that 76 gear box fits in the 1973 cases.what other parts will interchange.will crank and ignition swap.i know the barrel is different
cheers
jimg
8)
Author:  Stephen [ Mon Aug 06, 2007 7:00 pm ]
Post subject:  Re: cr250m 1973 will 1976 motor parts fit
Some will, some won't. For specific parts, I go to a site like
Discount Honda Parts that have the parts numbers listed and crossed to diagrams. If the part numbers are the same, they should fit. I use this quite a bit when looking at various parts on e-Bay.
Just for info, Discount Honda Parts doesn't have a lot available for vintage bikes. Just because they will let you order, doesn't mean that they have any of it in stock.
Author:  Elsinorestuff [ Tue Aug 07, 2007 10:37 pm ]
The complete transmission will fit in the 73 cases. The clutch and shift shaft are the same as well as the clutch cover. The crank will not work since the rod is longer in the 76 model. The ignition will work in the 73 but you can only swap the 76 into the 73. It may not work the other way.
Author:  jimg1au [ Wed Aug 08, 2007 7:29 am ]
could i use the crank if i put a spacer under the barrel i have seen these forsale on the web longer rod c/w spacer.to suit cr250 1973
cheers
jimg
