74 CR250M clutch cable routing https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1540 |
Author: | Dos Rios [ Wed Aug 15, 2007 10:13 pm ] |
Post subject: | 74 CR250M clutch cable routing |
Just curious as to to correct way to route the clutch cable. I've seen several different ways. How did the factory do it? Which side of the steering tube did it go? Was it under the front tank bolt? Thanks DR |
Author: | dogger315 [ Mon Aug 20, 2007 1:50 pm ] |
Post subject: | Re: 74 CR250M clutch cable routing |
According to the Honda service manual, the clutch cable is routed through the gap between the front number plate and the top triple clamp, then along the downtube to a special clamp a few inches above the front motor mount hanger plates, then on top of the left crankcase to the clutch actuator arm. dogger |
