It is currently Sat Aug 16, 2025 10:03 pm
 Post subject: 1980 cr250 wheel problem
PostPosted: Thu Mar 11, 2004 4:53 pm
i have a 1980 cr250r with a bad front wheel. i was given a wheel from a 1979 cr125. would it fit? and if so what would i have to do to get it to work? even if i have to respoke it to my hub that wouldnt be a problem the spoke count is the same. also i have a 21" wheel and this is a 23" wheel would it be ok to run for now? the bike will not be raced hard or beat up to badly. and if anybody knows where to get a good price on tires please let me know.
thanks, ryan
1980 cr250r
PostPosted: Thu Mar 11, 2004 5:15 pm
Ryan,
The stock '79 CR125R (23") complete front wheel will bolt up to the stock (OEM) front end of your '80 CR250R without any mods or issues, though it's not recommend because of the poor tire selection (I believe that Cheng Shin is the only supplier for them?). As far as the differences go between the two wheels, the '79 CR125R only shares the hub assembly with the '80 CR250R (as well as the '78/'79 CR250R's), the rest (spokes, tire, rim and spoke drive sprocket) are all different. Hope that helps...
Take care,
Robert
PostPosted: Thu Mar 11, 2004 6:23 pm
thanks Rhawes that does help me out alot.
ryan
1980 cr250r
PostPosted: Thu Mar 11, 2004 6:41 pm
Won't you have to drop the forks in the triple clamps to make up for the larger front wheel?
PostPosted: Thu Mar 11, 2004 10:35 pm
Hey Robert,
Where can you get the Cheng Shin 23" tires? I'm switching to 21", but it would be nice to have a new tire on my old wheel. 8)
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Fri Mar 12, 2004 12:15 pm
J,
Here you go...
http://www.denniskirk.com/jsp/product_c ... leafCatId=
Users browsing this forum: Bing [Bot] and 12 guests
