Yes the rod is in and the "cup" that poushes on the outside part of the clutch that turns the input shaft of transmission is there. There is a black splined washer that is fairly thick that I'm not 100% on where it goes. By the diagrams I'm looking at it has to go begind the inner clutch basket
http://www.cmsnl.com/honda-cr250r-elsin ... E++04.htmlIn that diagram the washer is #14 and I ahve it placed there currently. It is a splined washer but sits behind the splined area on teh trans input shaft and is slightly loose on the shaft. Is this how it should sit? Seems kinda odd to me, but if it were to sit in the splined area tehre's no way that clutch pushrod could push far enough to release.
So with the clutch assembled as shown in the picture I have to adjust the cable WAY out to get it to release. The two nuts on the lower adjustment part of the cable... Only the nut towards the front is on the cable. To get it to release I have to back the toehr one all the way off and let it hang loose. Seems like something is not right. Before going through the engine it was backed out pretty far but both nuts were securely holding the cable to the lower adjustment mount.
I tried assembling without that splined washer that seems a little loose on the shaft (#14) and the clutch would release fine but not apply all teh way. Some sort of spacer/thrust washer needs to be there to hold the inner basket (#4) close enough to the pressure plate (#6) to engage the clutch fully. I'm 99% sure this is the washer that came from that position as it only seemed to fit there when pulling it apart, and I had it set aside with the clutch stuff.
This is my first time taking apart one of these engines so I could be mistaken, but doubtful as I tried to lay things out in the way they came apart. Any thoughts?
