My 78 CR125 boggs TERRIBLY
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=163
Author:  wayne57144 [ Tue Mar 09, 2004 11:53 am ]
Post subject:  My 78 CR125 boggs TERRIBLY
I need some serious advice please. I bought a rebuilt 78 cr125 and have never gotten it to run properly. It starts easy, idles fine, and run well at high rpms. The problem is--It won't make the transition from low rpms to midrange. It really bogs and shoots gas into the airbox.The carb is stock and I've made all adjustments I can think of.....tried different size main jets, tried a leaner slide, tried all positions with the clip on the needle. Nothing I do makes any difference with it bogging. I live in the Myrtle Beach area, so I don't think altitude is an issue. I've even split the cases to see if i had a bad seal (there wasn't) and replaced all gaskets and oil seals. The only thing I can think of is maybe the CDI or stator could be faulty. Is this a possible source of the problem? The pilot jet is stock and wouldn't think would need changing. I've got several hundred $ in this thing and still can't ride it yet! Can someone out there PLEASE HELP ME! Thanks, Doug
Author:  Rickk [ Tue Mar 09, 2004 11:55 am ]
Just a thought, does it have reeds?
Could be the CDI or stator. I fought a KTM doing this type of thing and the pickup (stator?) finally let go 100%. Not fixed yet so I don't know if that was the original problem. See if you can borrow a couple pieces...
Oh, check the plug cap too. Maybe....?
Author:  Rhawes [ Thu Mar 11, 2004 4:54 pm ]
Post subject:  '78 CR125M boggs
Hi Doug,
Sounds like your float height is set incorrectly and/or a bad needle and seat. Timing could be an issue as well, the failure of electronics on these bikes will usually result in making the bike difficult to start and/or performance at high RPM's or under heavy loads.
Good luck,
Robert
Author:  redrocket190 [ Thu Mar 11, 2004 6:56 pm ]
Sorry to add to the list, but if gas is being kicked back into the carb, check the reeds out too...cracks, closing all the way etc.
Author:  Rhawes [ Fri Mar 12, 2004 1:49 pm ]
Post subject:  No Reeds...?
Doug,
The Ì78 CR125Ìs didnÌt have reed valve cylinders unless they were Mugen kitted (or had some other type of aftermarket reed setup)÷the Ì79 CR125RZ was the first production CR125 with a reed valve cylinder.
Take care,
Robert
Author:  MXRose3 [ Mon Mar 15, 2004 1:16 pm ]
Post subject:  CR bogging
I just got another 83' CR125 to fix up and it was bogging/hesitating like crazy. I finally tracked it down to a bad stator coil. Luckily i have another 83' to swap parts with, but i still had to go thru trial and error to find it. I started by swapping the carb, then the reed valve, then the coil, then the cdi, and finally the stator is what did the trick. After i tested it with an ohmeter it was about 30 ohms off from the good one.
Bob
