83 CR250 Aluminum Rear Sprocket needed
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1630
Author:  whymee [ Fri Nov 02, 2007 4:06 pm ]
Post subject:  83 CR250 Aluminum Rear Sprocket needed
I am having a problem locating an alum. rear sprocket for my 83 CR250. 54 tooth. I might consider a 55T. Any leads?
Thanks in advance.
Stan
WV
Author:  redrocket190 [ Fri Nov 02, 2007 5:34 pm ]
Post subject:  Re: 83 CR250 Aluminum Rear Sprocket needed
http://www.sprocketspecialists.com
Author:  whymee [ Mon Nov 12, 2007 6:53 am ]
Thanks Michael. One other Q.
What year sprocket fits the 83 250? I am getting conflicting specifications from the various manufactures. Some say 83-87, some do not include the 1983 model.
Again, thanks in advance...
Stan
WV
304-265-0670
Author:  redrocket190 [ Mon Nov 12, 2007 11:09 am ]
Go to http://www.cmsnl.com and navigate to the appropriate parts list for the '83 Honda CR250R. When you select the OEM rear sprocket, it will show you a list of other models that use the same part.
