suitin up CR125m 74
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1645
Author:  74elsinore [ Tue Nov 20, 2007 7:49 pm ]
Post subject:  suitin up CR125m 74
hey i was trying to figure out some ways to imporve the performance of my cr, i was thinking about 32 milki card or should i do 34mm. Also which is the best pipe to get, i see alot of people have pro form. Also a superflow filter. Does anyone change the sprocet size or keep to stock after all that. Is there anything else i can do?
Author:  frohrs [ Wed Nov 21, 2007 9:32 am ]
Post subject:  Re: suitin up CR125m 74
I think a 32mm Mikuni with a pipe and some porting is a good choice. I would recommend a rod kit too! Pro-Form pipes are nice & quiet at an idle. However I prefer the FMF pipe or the DG.
I run the 1975 filter.
Gearing is a mater of choice, tracks, and your weight.
I'm 180 and run a 14 counter & 52 rear. That works for me!
You might look into getting a good aftermarket arm & shocks.
Good Luck
frohrs1
