It is currently Fri Jul 18, 2025 7:58 pm
PostPosted: Wed Dec 19, 2007 9:03 pm
Looking for a longer shift lever for 79 CR250. I had a chance to speak with John @ Hammerhead Design.
There might be a chance the BMW 1200 shift lever might work. Need to know if the splines on the newer Honda is the same as the 79s.
The lever is 120mm long from center of spline to tip hole can be longer with tip selections. Offset is 1/2" from the end of spline mount.
PostPosted: Thu Dec 20, 2007 11:07 am
I am currently running a shifter from an '02 CR250 on my 1976 CR. Spline is exactly the same, so I don't think Honda has changed the spline over the years.
