Is there a differnce between the cr250m and cr250m1 cylinder https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1681 |
Author: | woosh [ Thu Dec 20, 2007 9:22 pm ] |
Post subject: | Is there a differnce between the cr250m and cr250m1 cylinder |
I just bought a cr250m1 gp cylinder to put in my mt250 I still need a head. Anyway just wanted to know what the differnce between the two bikes was as I also wanted to put on the mossburger reed valves and they are for 73-74. Bikebandit shows the 73-76 bikes all use the same cylinder so as far as I know they are the same. Anyway I need help as I know nothing about these bikes and what was interchangable. |
Author: | frohrs [ Thu Dec 20, 2007 11:39 pm ] |
Post subject: | Re: Is there a differnce between the cr250m and cr250m1 cylinder |
The 75-76 cylinders are not the same as the 73-74. The 75-76 had an up pipe which the exhaust port is on the left hand side of the bike when sitting on it. The 73-74 exited out through the right side. I'm not sure how the porting has chaged through 73-77 if any. For a good look at a restored 1975 CR250 go to Vintage Factory.com and check it out! Good luck. frohrs1 |
Author: | expat [ Thu Dec 20, 2007 11:49 pm ] |
75/76 have a crude "boost port " or 5th port in rear of cylinder above intake. The cylinder hold down stud spacing is very different to 73/74 so cylinders are not interchangeable. |
Author: | woosh [ Fri Dec 21, 2007 12:00 am ] |
So then I have to use the 73-74 cr250 cylinder on my mt250 its a 75 does that matter? |
Author: | Dave [ Wed Jan 30, 2008 3:40 pm ] |
it does not matter what year MT it is.the mt motor along with the 73-74 cr250 motors,the cylinder and head will bolt on.dont forget to get a pipe,carb to compliment the CR top end. |
