Clutch basket bearings? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1693 |
Author: | GHOPPER [ Sat Dec 29, 2007 1:00 pm ] |
Post subject: | Clutch basket bearings? |
I am have trouble finding the 2 roller bearings in the clutch basket for a 76 cr250. I was told by the dealer honda no longer has them. Does anyone know of another year that will work. Thanks Ron |
Author: | mitchie [ Mon Dec 31, 2007 6:45 am ] |
Post subject: | Re: Clutch basket bearings? |
The bearings in these bikes are almost always a standard issue bearing manufactured by others. If you have your old bearings, you can likely take them to a bearing distributor (Allied Bearings or someone like that) and they can measure them and either sell you some or order them for you. Both bearings are the same, if I remember right. I haven't replaced those particular bearings, however, so I don't have the number you'll need. I'll bet someone else on this forum has been through this and can give you the size or bearing number you'll need. Good luck. |
Author: | Gary Starr [ Mon Dec 31, 2007 9:32 am ] |
Try here- http://www.mrcycles.com/fiche_select.asp I don't know if they have them,but they list the dimensions,25x29x17,with the new and old part#'s.I think all Honda part books list either size or number on all bearings and seals since as mitchie says they are a standard size. |
