Will a 250 kick start assembly fit in a 175? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=17 |
Author: | Caleb [ Sun Jan 25, 2004 8:12 pm ] |
Post subject: | Will a 250 kick start assembly fit in a 175? |
Will a kick start assembly made for a 73-74 250 fit in an 76 175? |
Post subject: | Re: Will a 250 kick start assembly fit in a 175? |
O ya the 250 is a CR and the 175 is a MR not sure if this matters or not. |
Author: | Jerry [ Sun Jan 25, 2004 8:13 pm ] |
No it mounts from inside the case the 250 mounts from the outside and is different. A CR125M or any MT125 mechanism is the same. You need to split the cases to install the shaft or return spring. |
