It is currently Fri Aug 15, 2025 7:17 am
 Post subject: honda 1976 cr250 tank
PostPosted: Fri Feb 08, 2008 5:12 pm
hi
if i use my cr250 76 tank on my 1973.and i use my 1976 as a race bike what tanks will fit.
mt 250 mr250 or any thing else
cheers
jimg
Jim Garvey
1x honda cr250m 1973 in bits
1x yetman triumph dirttracker
PostPosted: Thu Feb 14, 2008 10:01 am
MR250 tank will fit right on, and I'm 99% sure a MT250 tank will fit. any CR250 tank from 73 to 76 will work.
Don't believe the 125 MT will thought.
The MR175 is a different tank than the 250, shorter.
But...
I've found that you can make other tanks from the 70's will work on cr/mr's, that big hole in the frame up by the sterring head allows you to run a long bolt through it. Not all tanks align with the stock threaded tank bosses, but many will align with the frame holes.
I found 2 big rubber 'corks' at a local hardware store that fit into the big holes, one per side. I drilled a hole off-center in the corks, which allow me to rotate the corks to adjust positioning. using this method, I mounted (among other experiments) a Clark RC125 tank. Loved the way it looked, but lousy range inthe woods.
I'll try to find a picture of what i'm trying to explain.
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
