It is currently Fri Jul 18, 2025 11:06 am
PostPosted: Tue Mar 04, 2008 8:49 pm
I'm looking at buying a 1981 CR80 for $200us cosmetically the bike is in ok condition
The bike has good compression with good spark but its won't start? I need some advice as to what other parts of this bike i should be looking over and what to look for?
Your help is greatly appreciated
PostPosted: Sat Mar 08, 2008 2:01 pm
Have you tried squirting some mix into the open carb? If it fires and runs briefly then the timing is probably right and the carb has a problem like stuck floats or blockage.
If it doesn't fire and run, then it could be a broken flywheel key throwing the timing off.
