78 CR250 Head Gasket
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1833
Author:  78redracerguy [ Sat Apr 19, 2008 11:15 am ]
Post subject:  78 CR250 Head Gasket
Hello all. I bought a new head gasket for my 78 CR250. Do I just put it on as is as it is a copper gasket? Or are you supposed to put something on it when you install it?
Author:  redrocket190 [ Sat Apr 19, 2008 1:15 pm ]
Post subject:  Re: 78 CR250 Head Gasket
As is, will be fine.
Author:  78redracerguy [ Thu May 01, 2008 10:54 pm ]
What torque ratings should i tighten the head bolts to?
Thanks!
Author:  redrocket190 [ Fri May 02, 2008 9:21 am ]
Go the Reference section and download the manual....
Author:  78redracerguy [ Sun May 04, 2008 9:27 am ]
It says in there to torque the cylinder nuts to 28-35 lb ft but I cant see anywhere where it tells you what to torque the head nuts too? Can you please let me know as I have been wanting to change my head gasket and dont want to until I know the proper torque....
Author:  b-joe [ Sun May 04, 2008 10:13 am ]
17,4 - 20,9 lb ft
Author:  78redracerguy [ Sun May 04, 2008 11:20 am ]
9 lb ft? What is the "17, 4-20" mean in your post?
Author:  dogger315 [ Sun May 04, 2008 12:14 pm ]
17,4 - 20,9 lb ft means 17.4 to 20.9 lb-ft
Author:  78redracerguy [ Sun May 04, 2008 1:15 pm ]
Thank You!!
Author:  redrocket190 [ Sun May 04, 2008 3:43 pm ]
Page 66 - Cylinder Head - 14.5 to 16.6 ft lbs. Snug them down hand-tight and then torque using a criss-cross pattern.
Author:  78redracerguy [ Sun May 04, 2008 4:02 pm ]
Uh Oh..... I already did it earlier this afternoon and torqued to 20 lbs ft... I took it for a ride and it seemed fine... what problems is this going to cause me over torquing them like this? And yes I did the criss cross pattern when tightening them....
Author:  spannerman167 [ Sun May 04, 2008 5:23 pm ]
Just ride it it will be fine.
You obviously haven't stripped the threads or distorted anything so you have no worries.
Author:  b-joe [ Mon May 05, 2008 12:01 pm ]
sorry, in europe we use ","
for you it`s 17.4 - 20.9 lb ft
