powder coating rims https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1867 |
Author: | badsix [ Sun May 18, 2008 10:12 pm ] |
Post subject: | powder coating rims |
has anybody ever powder coated there rims i have some did rims that are in good condition other than being all scrached up from tire irons and screw drivers i would like them gold anyway like 87 cr125s there going on a 79 cr125 thanks jd |
Author: | dogger315 [ Mon May 19, 2008 8:55 pm ] |
Post subject: | Re: powder coating rims |
Powder coating your rims would work fine. The DIDs are extruded aluminum that were clear anodized, powder coating would be just as durable if not more so. I would clean the rims thoroughly and check them for cracks at the welds then wet sand the scratches and gouges. Finish them off with a media blasting using aluminum oxide to give the powder a good surface to adhere to. If you want a straight gold finish, you can coat them, cook them and go. If you are looking for a gold anodized finish, you will need to do a base coat top coat process. Either way, they should look great. dogger |
