'82 480 motor in a '83 250 frame? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1874 |
Author: | motohunter4 [ Sat May 24, 2008 2:29 pm ] |
Post subject: | '82 480 motor in a '83 250 frame? |
will it work? |
Author: | motohunter4 [ Sun May 25, 2008 11:20 am ] |
Post subject: | Re: '82 480 motor in a '83 250 frame? |
i was also wondering if you can use the cdi and coil from the 250? they look the same, dont have the 480 yet so just thought id ask a few questions while i wait on ups. |
Author: | b-joe [ Mon May 26, 2008 11:38 am ] |
it will fit. you can use the 250 coil but the cdi is another. the 480 will run with the 250 cdi but not realy good. |
Author: | motohunter4 [ Tue May 27, 2008 10:03 am ] |
thanks for the info, i guess ill be looking for a 480 cdi |
Author: | motohunter4 [ Fri May 30, 2008 9:57 am ] |
well there is one roadblock ive run into, and that is you have to cut out the lower radiator mount. |
Author: | motohunter4 [ Wed Jun 04, 2008 9:57 am ] |
gas tank mount is different too, you have to cut off the mount, then fabricate brackets to secure the gas tank. i have everything in now and it looks good, let you know how the test ride goes.... |
Author: | redrocket190 [ Wed Jun 04, 2008 10:34 pm ] |
OK, I'll ask. Why? |
