cr250 1979
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1888
Author:  allyscot [ Tue Jun 03, 2008 2:14 am ]
Post subject:  cr250 1979
hello all,
i hope you can help me i just converted to honda from suzuki and i am fitting 17.5 fox shox to my 79 cr250 can any one tell me good pressure to run them at . im 215bls Intermediate rider i have showa 43mm forks on it. so if any one can guide me i would be very happy. :)
alastair
Author:  redrocket190 [ Tue Jun 03, 2008 9:50 am ]
Post subject:  Re: cr250 1979
From the Fox Shox manual....
Leverage ratio = 1.8 (stock, not DG or other after-market swing arm)
Bike weight = 210-230lbs
Rider weight = 220lbs with gear
(Upper) Low pressure = 91 psi
(Lower) High pressure = 146psi
The greatest thing about Fox Shox is you can so easily make adjustments to these settings. If you ever want these re-built or re-furbished, ask me about Brian Rivers in Florida.
Author:  allyscot [ Wed Jun 04, 2008 2:30 pm ]
many thanks i will try those pressures out on sat. :lol:
Author:  redrocket190 [ Wed Jun 04, 2008 10:33 pm ]
Check out the CR Reference section....
Author:  goneriding [ Thu Jun 05, 2008 8:03 pm ]
Michael, can pass on the contact info for Brian in Florida, I have a set of Fox Shocks that are in need of a rebuild and I live in the sunshine state. Thanks, Dave
