78 CR250 crank rod kit?
https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1908
Author:  SFx73 [ Sat Jun 21, 2008 6:44 pm ]
Post subject:  78 CR250 crank rod kit?
Hey guys, I'm new to the forum and would appreciate some direction. Where would I find a crank rod kit for a '78 CR250. Thanks.
Author:  redrocket190 [ Sat Jun 21, 2008 7:53 pm ]
Post subject:  Re: 78 CR250 crank rod kit?
Contact Racers' Toy Store (where I've been twice) or Crank Works and they'll find an IMS kit to fit.
Author:  b-joe [ Sun Jun 22, 2008 6:26 am ]
as i know is the rod kit from 78 to 01 the same.
Author:  redrocket190 [ Sun Jun 22, 2008 11:19 am ]
If my memory is correct the 1978-1980 CR250 share the same crank - or least the rod - with an early 80's ATC250R. And there is an IMS kit for the that.
Author:  oldpromxr [ Thu Aug 28, 2008 12:39 pm ]
Vintage elsinores has them. Thats where I got my kit for my 1980 cr250. Its a Hotrod p/n. When you look up that part number on the Hotrods website it says for later models but it works. Someone got the calipers out and did some measuring.
Author:  FTE [ Fri Aug 29, 2008 11:51 am ]
Honda, I believe, only sold the complete crank for the bikes. The rod, however, is the same as for the 1981-84 ATC250r. There are aftermarket rod kits for that. I bought two Vesrah kits off of Ebay, and Wiseco sells them as well. The rods definitely are not the same all Cr250 years through 2001. The 78-80 Cr250r rod is listed 64.4mm, the years after are listed at 72mm, with a different kit even then listed for 2002 on..
Author:  whymee [ Mon May 03, 2010 6:30 am ]
Ok Fellas...
Who is right?
Some say the rod kit from 78 to 01 the same.
FTE sez the rod is the same as for the 1981-84 ATC250r.
Who is right?
Anybody have part #'s from Hot Rods, Vesrah, IMS, Pro-X ect?
My "new" Elsie needs a rebuild.
Stan
WV
Author:  mx317 [ Tue May 04, 2010 11:19 am ]
The measurement you are talking about is stroke, not rod length. Re-Mx has them for $109. This company shows 78-2001 the same. http://www.motoxparts.co.nz/motoxspares.php?price_image=1&category=0&brand=102&page=1&piece=1097
Author:  mx317 [ Tue May 04, 2010 11:51 am ]
Detailed specs just to be sure http://www.mitaka.co.uk/HONDA%20RODS/CT.78CR250.htm
Author:  b-joe [ Tue May 04, 2010 3:45 pm ]
2 months ago i had a 78-80 crank to rebuild.
send it to my shop here in germany.
they installed a pro-x kit for 78-01.
the orig. crankpin 78-80 is 58mm long, later models uses a 60mm crankpin.
they shortend the pin for these 2mm and installed the kit.
that´s the secret. :D
Author:  FTE [ Wed May 05, 2010 10:53 am ]
I stand corrected! :oops:
So a current oem kit will work with small mods, eh?
Author:  whymee [ Fri May 07, 2010 8:56 pm ]
Wish some one would tell me what to do.... LOL
Author:  b-joe [ Sat May 08, 2010 10:18 am ]
do it like me.
Author:  redrocket190 [ Sun May 09, 2010 7:50 pm ]
Did you call Racers' Toy Store as suggested in the 2nd post?
Author:  whymee [ Thu Jun 03, 2010 11:27 pm ]
Sent my Crank & cylinder to "The Racers Toy Store". Seem to be nice folks.
After looking around for rod kits for this bike, I realized I had 2 kits for my 83 Cr250. An OEM & a Hot Rods. I send both with the crank.
Will report back once I have reconditioned parts in hand.
Thanks Michael for the heads up on the "Store"!
Stan
WV
