It is currently Fri Jun 20, 2025 10:34 pm
 Post subject: Bead/Rim lock
PostPosted: Mon Jul 07, 2008 10:02 am
I am putting a cr250m rear wheel on my mt250 and wanted to know if it was supposed to have a bead lock on it mine does not but there are several holes in the rim so maybe someone took it off? Also where can you buy innertubes with the correct schrader valve so I dont have to drill out the hole to fit a modern schrader valve in.
 Post subject: Re: Bead/Rim lock
PostPosted: Mon Jul 07, 2008 10:06 am
ok I found the bead stoppers at bike bandit for 26 bucks I would still like to know where to get the correct innertubes.
PostPosted: Mon Jul 07, 2008 12:42 pm
a schrader valve has 7.7 mm OD and the hole in the rim is normaly about 8,3mm.
what do you have?
PostPosted: Tue Jul 08, 2008 2:20 am
I thought I read on here a while back that the 73 74 cr250 had a smaller hole that didnt work with todays valves and that someone still sold the corect tubes. I may be wrong I dont have my rim at the moment but can measure it tommorow.
PostPosted: Tue Jul 08, 2008 6:41 am
Woosh,
Different subject... Did you get the Mikuni from Elsinores.com ? And did the manifold fit better than the stock one that you had? Still want to order one but want to use the original manifold if it fits.
It's a money thang.
Thanks,
Jeff
Jeff Smith
'78 Husqvarna CR250
'74 Honda CR250
'73 Bultaco Pursang 350
'78 Honda Z50 ( kids baby )
PostPosted: Tue Jul 08, 2008 10:20 am
I did get a carb and manifold form vintage elsinores. It fits the cylinder real good but I had to remove the airbox and am going to put a pod filter on it. I am also gonna have to relocate the battery. This is on an mt250 not sure how similar the cr250 frame is to the mt250. The stock carb on the mt250 was a 28mm I think so I had to get the manifold as there was no way to get the new carb in the old manifold.
PostPosted: Wed Jul 09, 2008 10:05 am
Woosh,
You can get the correct look valve at http://www.denniskirk.com. I use Kendas with the TR-6 valve which is the same
type of valve as the OE tube. Current bikes use a TR-4 valve.
PostPosted: Wed Jul 09, 2008 12:57 pm
can“t find a difference between the two valves except the fitting to the tube????
PostPosted: Wed Jul 09, 2008 2:59 pm
TR-4 valve stem is 25mm, TR-6 is 30mm to accommodate the deeper dishing in the old style rims. Honda also specifies
a nut be threaded on the rim lock between the rim lock flange and the rim for the same reason.
PostPosted: Sat Jul 12, 2008 11:14 am
Sorry one last question does the mr250 front rim use the tr-6 or the tr-4 innertube?
PostPosted: Sat Jul 12, 2008 4:36 pm
You can use either one. The TR-6 valved tube is what came on the bike originally.
