1980 CR250R fork diameter ?? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1944 |
Author: | boatfixer27 [ Thu Jul 17, 2008 9:27 pm ] |
Post subject: | 1980 CR250R fork diameter ?? |
The fork tube diameter on mine is 38 mm with straight tubes, I thought stock was 37mm with the indentations at the top between the triple clamps. My bike was mfg'd 1/1980, it seems odd since I thought the upgrade usually was to 41's from an 81 or 43's from an 83. |
Author: | dogger315 [ Fri Jul 18, 2008 9:39 am ] |
Post subject: | Re: 1980 CR250R fork diameter ?? |
You are right about the stock fork diameter. The 78 -80 CRs used the same '430' top triple clamp that fit a 37mm upper fork tube. The straight (no indention) larger upper fork tube didn't show up until 81. I don't know why your bike has 38s. The CR450 used the same forks and bridge as the 250 so I don't know off hand what bike (if any) originally used that size. Maybe you're in posession of a rare set of "works" forks ![]() dogger |
Author: | boatfixer27 [ Tue Sep 02, 2008 7:31 pm ] |
I finally figured out what forks I have on this bike after trying to track down a replacement damper rod bolt which was a 12 mm x 1.25 pitch (extra fine metric), and the only forks that had this were Showa 38 mm's from a 1981 CR125. I still don't know where my triple trees came from since the handlebars have a rubber mount usually found on enduro / dual purpose bikes. |
Author: | FTE [ Tue Sep 02, 2008 7:33 pm ] |
Maybe from an XR? |
Author: | boatfixer27 [ Mon Sep 15, 2008 7:43 pm ] |
Does someone know the fork oil level / height or volume required to fill these forks (81 CR125)? Many thanks, this forum helps fuel my addiction (6 CR250's and 8 others) |
