1978 CR250 cylinder-Sleeve vs Rechrome https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=1985 |
Author: | SFx73 [ Fri Aug 08, 2008 6:57 pm ] |
Post subject: | 1978 CR250 cylinder-Sleeve vs Rechrome |
I have a '78 CR250 that hung a ring and damaged the cylinder. Does anyone have any experience with a sleeved cylinder compared to a rechromed cylinder? I will only race this bike about 4 times a year and practice with it a little more. Also, if I rechrome it, what would be an average price? Thank you. |
Author: | FTE [ Mon Aug 11, 2008 12:54 pm ] |
Post subject: | Re: 1978 CR250 cylinder-Sleeve vs Rechrome |
Personally, I go for Nikasil replating (I don't think you'll find a place to rechrome) over sleeving. The upside to sleeving is that you can do overbores down the road when you need to have a fresh top end. The downsides are that the sleeves rarely perfectly match for the ports (though you could probably smooth that out with a proper epoxy) and that the cylinder is no longer as thermally efficient. I think the up front cost is roughly the same if you factor the cost of the sleeve in. Replating is about $200, with a bit more if the cylinder needs a deep gouge repaired. The replating services I see mentioned the most with good reports are: http://www.usnicom.com/ (I believe Eric Gorr uses them) http://www.powersealusa.com/ http://www.mt-llc.com/ |
Author: | Moto_Recon [ Wed Aug 13, 2008 12:29 pm ] |
Hello, The damaged chrome can be stripped. If there's damage to the aluminum bore, it can be rebored to the next cleanup size and then replated , Nikasil, whatever. This way you don't need to worry about port alignment, or a poorly fitting sleeve. If you bore and replate, you have just given yourself a new, your standard, bore size. |
