It is currently Fri Aug 15, 2025 9:58 am
PostPosted: Wed Nov 05, 2008 2:24 am
HI
just fitting my new reconditioned stator to my cr250 1973.any tips on the best timing set ups
i think factory is 1.5mm btdc
cheers
jim
almost ready to start after 25 odd yeard lying in the sun in texas will fire up in sydney australia
i am the 2nd owner
cant wait workis interfearing though
Jim Garvey
1x honda cr250m 1973 in bits
1x yetman triumph dirttracker
PostPosted: Wed Nov 05, 2008 11:12 am
Honda recommends 1.8 to 2.0 BTDC in the manual. Honda racing recommended 1.5 BTDC which is probably
a better (field tested) setting.
Use a dial indicator to find TDC then back it off to whatever setting you prefer. I use a multimeter to indicate
when the points open (see pic). With the dial indicator indicating your preferred advance number, turn the
stator plate until you get an indication from the multimeter and lock it down. You're done.
[img]Image[/img]
PostPosted: Wed Nov 05, 2008 9:42 pm
I sure liked the way Honda did these motors timing, easy to do, pretty fool proof. Imagine my surprise when I got my MR several years ago. I dig out my old dial indicator set up I bought for my CR back in the day ($37.95) Oops don't work, you adjust them by changing the point gap, how crude.
PostPosted: Thu Nov 06, 2008 5:27 pm
thanks all good 1.5mm btdc
big fat blue spark.
18thou points gap
cheers
Jim Garvey
