It is currently Fri Jun 20, 2025 1:41 pm
 Post subject: CR480 running rough
PostPosted: Sun Jan 04, 2009 11:29 pm
I picked up another 83 CR480 and it started just fine but ran rough. I replaced the carb with one I intend to use on the CR I'm rebuilding and it still runs rough.
It will idle without the choke on but it seems to kind of sputter when I roll the thottle on. It did exactly the same thing with the other carb. Both carbs have stock jetting and I adjusted the air screw 1 1/2 turns out.
Any suggestions on what I might look at next to resolve the problem?
Thanks for the help,
Jim
 Post subject: Re: CR480 running rough
PostPosted: Mon Jan 05, 2009 7:15 am
mine had bad crank seals is it smoking more than normal or can you smell gear oil in the exh.
PostPosted: Mon Jan 05, 2009 5:52 pm
Three obvious variables....
1. Jetting. Stock CR480R jetting is rich. You need 152-ish main and a 70 pilot. Plus raise the clip on the needle.
2. The carb is worn. Eliminated if it is new and/or works fine on another bike. (I think you are OK on this one.)
3. Primary drive crank seal is worn. Transmission oil will make exhaust smoke.
Users browsing this forum: No registered users and 46 guests
