74 CR250M kick starter https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2126 |
Author: | yodadada [ Sun Jan 04, 2009 11:33 pm ] |
Post subject: | 74 CR250M kick starter |
I recently got another kick starter for one of my Elsinores. Problem is, it's almost as loose as the one I have. Is there any way to rebuild one of these kick starters? Thanks, Jim |
Author: | dogger315 [ Mon Jan 05, 2009 11:52 am ] |
Post subject: | Re: 74 CR250M kick starter |
I'm betting if you remove the knuckle from the kick start lever, the hole in the lever where the pin you just removed goes, is elongated. There is a good chance the hole in the knuckle is too. Some guys drill those holes out and sleeve them with a soft metal (brass, copper, etc.) bushing that is a tight fit on the pin. I prefer to fill weld the holes then drill a new pin hole. It's also a good idea to check the spring tension while you have it apart, replace if neccessary. The first method doesn't require any welding cost or skills and won't discolor the metal neccessitating a re-chrome. The second method should be a longer lasting fix. Both should eliminate the "floppy lever syndrome." dogger |
