It is currently Thu Aug 14, 2025 6:45 pm
 Post subject: Mt250 ignition timing
PostPosted: Tue Jan 20, 2009 11:20 am
I need to time my mt250 and not sure how. I have put a cr topend on it but still am using the mt ignition. The timing for the cr is 1.5 btc but the shop manual says the mt is 20 btc thats way different. I guess I gotta time it the way the mt is as thats the ignition I have. Is this timing gonna work right?
PostPosted: Tue Jan 20, 2009 12:41 pm
What tools do you have to set the timing? There are two basic methods to set the points gap accurately:
1) Feeler gauges and automotive-type timing light
2) Dial indicator and points-opening light
You can also just set the points gap to the middle of the recommended range using feeler gauges, but this is just a guess even with brand-new points, let alone used ones.
I'd suggest 18 degrees BTDC for your bike.
For what it's worth, a CDI ignition from a '75 - '77 CR250 would be a real upgrade. The tiny rotor will allow the motor to rev much quicker, and adjusting the timing is a really easy, set-and-forget type of deal. They pop up on eBay all the time.
Users browsing this forum: Bing [Bot], Google [Bot] and 36 guests
