cr480 front brake hub differences?? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2194 |
Author: | montywa [ Tue Mar 10, 2009 11:13 am ] |
Post subject: | cr480 front brake hub differences?? |
Searched the forum but no answers. Seems that brakes are the hot topic lately. I am swapping a cr480 front wheel onto my 80 cr250 for the better brakeing. My problem is that i do not know what year the wheel was and i want to order up new brakes for it but the brakes are year specific from 82 to 83. anyone have any ideas on how to determin what year wheel i have? i though that maybe the drum diameter may be different from year to year but i do not know the specs from honda. |
Author: | b-joe [ Tue Mar 10, 2009 1:15 pm ] |
Post subject: | Re: cr480 front brake hub differences?? |
drum diameter is always 130mm. 83 has straight spokes and holes in the larger brakelever. |
Author: | montywa [ Tue Mar 10, 2009 2:02 pm ] |
my primary lever does not have the lightening holes in it. I have an 82 front wheel. thanks for the help! I am assuming the differences in the pads are the diameter of the pads to make up for reduced travel due to the longer lever arm?? |
Author: | b-joe [ Wed Mar 11, 2009 10:37 am ] |
left 82, right 83 ![]() |
Author: | redrocket190 [ Thu Mar 12, 2009 9:08 am ] |
http://www.cmsnl.com/honda-cr480r-82-us_model1061/partslist/F++0501.html http://www.cmsnl.com/honda-cr480r-82-us_model1061/partslist/F++0502.html Links to the appropriate parts fiche.... |
Author: | sobodos [ Thu Mar 19, 2009 2:58 pm ] |
The brake backing plate on the 1982 cr480 has the return spring that wraps around the shaft on the actuator arm, and on the 83 it's a coil type that attaches to the tail end of the arm and a tab on the backing plate. I have found that the easiest way to ID the year of the wheel is to check the DOT. month and year stamp on the rim, 9/82 and up is 1983 |
Author: | RedRider43 [ Sun Apr 19, 2009 12:47 pm ] |
Just wondering I too have an 80cr250 that I just bought. Will the 82 or 3 double leader fit in the stock 80 hub? |
Author: | b-joe [ Sun Apr 19, 2009 3:58 pm ] |
RedRider43 wrote: Just wondering I too have an 80cr250 that I just bought. Will the 82 or 3 double leader fit in the stock 80 hub? no |
