1973 honda cr250m difference in crankshafts? https://vintagedirtbikeforums.alp-sys.com/viewtopic.php?f=21&t=2208 |
Author: | mark ayer [ Mon Mar 23, 2009 10:10 am ] |
Post subject: | 1973 honda cr250m difference in crankshafts? |
hello, i need some help please.i have a very early cr250m engine that has the serial number stamped in a straight line across the block.it has the billet crank in it.my question is will the later style forged/cast crankshaft work fine in this original block or will it cause problems? as you know it is shaped a bit different.thank you for your time! Mark Ayer mailto:jarrett8@earthlink.net |
Author: | dogger315 [ Mon Mar 23, 2009 2:31 pm ] |
Post subject: | Re: 1973 honda cr250m difference in crankshafts? |
Mark, The billet and cast cranks are interchangeable. If you have a billet crank in good shape, use it. Billet/forged cranks are stouter than the cast units. dogger |
