It is currently Fri Aug 15, 2025 11:59 am
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2  Next
PostPosted: Mon Dec 22, 2008 1:40 pm
Started off with this basket case.
PostPosted: Mon Dec 22, 2008 1:42 pm
Progress so far
PostPosted: Mon Dec 22, 2008 1:44 pm
I aquired these new Ohlin's,there slightly shorter than stock so I've moved the stock swingarm mount slightly forward to retain the correct height.
PostPosted: Mon Dec 22, 2008 1:50 pm
Motor completly stripped,all new gearbox and main bearings using only high quality bearings.
Luckly gearbox was like new, Big end was trashed, new rod kit fitted using a matched up kit from an RD Yam. 79/80 CR125 kits seem to be unavailable unless you have the crank line bored for a larger big end pin.
Just need to get cylinder replated and a piston.
PostPosted: Mon Dec 22, 2008 1:52 pm
All stock bolts cleaned up and plated.
PostPosted: Mon Dec 22, 2008 6:01 pm
Very nice work spannerman.
How did you accomplish this? Did you remove the stock mounting tabs
then fabricate and attach new ones?
Looking forward to seeing the finished product.
PostPosted: Mon Dec 22, 2008 10:13 pm
spannerman, looks like your off to a great start. after seeing pictures of your other 125 i'am shure this one will be awsome. i wish i was that far along. just got my crank back i had the later cr pin installed. so did you powder coat your frame and engine cases. allso what fenders are you going to use? i got a set from vmracingonline, very nice fenders but the red dos'nt mach the stock red on my 79 cr125. but i'am looking at old faded paint i'am not shure how they will look with new paint. i do have a honda xl200r that i painted with dupont red toner only then clear. this is a dead on mach with the fenders. my cr is going to be a rider and vitage racer but its got to look gooood !
PostPosted: Tue Dec 23, 2008 1:09 pm
Cheers.
Firstly I had to remove all the welded bracketry that had been welded on previously but leaving the origonal rear mounts attached,then I made up new plates which would act as the new slightly forward mounts these are welded to the origonal mounts.
PostPosted: Tue Dec 23, 2008 1:14 pm
As you can see I've left the origonal mounting hole so I can go back to the stock mounting should I wish.
PostPosted: Tue Dec 23, 2008 1:26 pm
:D
The frame was blasted back to bare metal then my mate sprayed it for me,its not powder coated.
He used 3020 (I think).
I stripped the motor then removed all the old paint using wire wheel,abrasive paper etc and left the finish slightly keyed up.
I then sprayed it with the high temp paint supplied by Red Rocket racing I think you can get this from VMX racing as well.
Finished off by baking the cases for an hour or so.
Then when cooled I rubbed off the paint from the protuding Honda name with fine grit paper.
Not sure where I'm going to get the plastic's from probably VMX or DC plastic's alot depends on my son's budget as I'm building it for him it will be his first bike :shock: :lol: .
PostPosted: Wed Dec 24, 2008 11:11 am
A simple but effective solution - nicely done.
I also would like to commend you on some first
class welds. Those brackets look like they are
original equipment.
That is going to be a sweet ride when done.
PostPosted: Wed Dec 24, 2008 4:56 pm
Something I forgot to mention,back in 79 I had a 79 CR125 here in the UK, there was a publication (motocross action I think) giving instructions on how to convert to a 21" front wheel by cut and shutting the top tube to alter the rake to suit.
Back then my Dad made the required jig and carried out that convertion on my bike after which he swopped the jig for some tyres with a local frame builder this guy then carried out these conversions for other 79 CR125 owners.
The irony is is that this bike has had that conversion and as I know of no other person doing that conversion in the UK I can only assume at one point it was on my late fathers jig.
Unfortunatly this one isn't my old bike.
Thought some of you may find that interesting.
PostPosted: Wed Jan 21, 2009 9:06 pm
Here you go, this is a photo from when your frame was converted 30 years ago, i'm 100% certain its the one because it was the only one which had the swing arm modified too, those shocks had come off my 78 Maico. :D
PostPosted: Wed Jan 21, 2009 9:11 pm
Where did you find that bike? I'm pretty sure i had that about 14 years ago but sold it when i cleared out all my 125's. The missing bits would have gone on my 1980's. :D
PostPosted: Thu Jan 22, 2009 12:23 pm
have you ever tried the rear holes?
think you´ll get in trouble with the springholder. :(
Users browsing this forum: Bing [Bot] and 14 guests
