It is currently Thu Jul 03, 2025 10:34 am
PostPosted: Sun May 02, 2004 12:16 am
I have a 78 cr250 and when I sit on the bike the front suspension drops about 3 inches alot farther then it should. Kinda like u dont even have to sit on it just the weight of the bike drops it down almost. Should I put thicker fork oil in or whats the deal? I'm guessing something else? I think I need new front and rear suspension.
PostPosted: Sun May 02, 2004 11:44 am
I'm no expert, but I would think it needs new springs for whatever your weight range is. Maybe you could pre-load them with a 10-15mm piece of PVC pipe or find some air caps until you get the new springs.
J
#829 The "Factory Novice"
1988 Honda CR250RJ
1983 Honda CR480
1981 Can-Am 250 MX6-B
1979 Honda CR250RZ
1979 Kawasaki KX250 A5
1978 Husky 250CR
1978 Honda CR250R
1977 Yamaha YZ400D
1977 Suzuki RM125B
PostPosted: Sun May 02, 2004 9:22 pm
Here's a link to a good article from Race Tech on how much preload to give your front end.
http://www.race-tech.com/articles/Suspe ... prings.htm
I have mine set up a bit stiffer than the article calls for.
HTH,
Loren
Users browsing this forum: Google [Bot] and 31 guests
